My '69 427 was originally equiped with an L71 with cast iron heads but now has aluminum L89 heads. The front height is even or perhaps slightly higher than the back. I believe the rear height is correct so I'm wondering if the alum heads could cause the front to be higher. I seen other 69's with a slight rake back to front which I prefer or simply lower overall. Would an L89 equipped car have different front springs than a standard L71? Does an F41 equipped car have a different ride height? Any way to adjust the front height without swapping out springs or other components?
Jack
Jack
