I'm trying to help out a friend and need to know the correct fan configuration for a 60 Corvette fan and fan clutch. Part numbers would be helpful if possible!
From what I have read in the archives, it should be a standard 5 blade fan used from 60-70, should have a fan clutch and a spacer should also be used. He currently has an incorrect fan with no clutch and it overheats constantly. I assume the correct configuration will help immensely when the fan is positioned correctly in proportion to the shroud.
Any help would be appreciated!
Mark
Mark
