Can anyone supply me with a pic of the 65 left front inner fender where the regulator and horn relay are? I need to see the plastic clip location for the wiring harness. I replaced the front end and the dimples were there for the other two but no dimple for the forward one. Looking at the aim I could be an inch off real easy. Mine has A/C if it makes any difference and a small block. Thanks, Mike
C2 Inner Fender Help
Tags: None
- Top
Re: C2 Inner Fender Help
Michael, Here are two views of mine. The hood is off, prepping the AC for trip to Nov. Let me know if you want another view. Good luck, Don H.
Attached Files- Top
Great pictures Donald! Exactly what I needed. Good luck on your trip and thank you so much, Mike!!- Top
