I have a bit of a confusing situation going on. Today I put the rear tires on for the first time since I rebuilt the rear end. When I tightened down the rim, the wheel would no longer spin. I traced the problem to the drum interfering with the backing plate. Once I loosened up the lug nuts, the wheel would rotate.
As part of the rear overhaul, I replaced the axle bearings. They are the newer sealed type with two o-rings. When I first installed the axle, I used the spacer and found that with the spacer, I could not get the axle end cap to seat to the backing plate properly so I removed the spacer and everything went together fine. I had read somewhere that the spacer was not necessary when using the newer style bearings as they are thicker then the original ones.
With what I experienced today, it looks like I need some sort of spacer. As an experiment, I put a 7/16 washer over each lug and then installed the drum and installed the tire. Everything rotated easily so I need to move the axle out a smidge.....
Any ideas?
Tom
PS the drums are new.
Any ideas?
Tom
