Re: High pressure vs. low pressure oil pump
I think all of your questions have been answered, but their nature indicates that you don't understand the issues.
There are 3 basic small block oil pump configurations.
1. OE standard volume, standard pressure (40-45 psi)
2. OE standard volume, high pressure (55-60 psi)
3 Aftermarket HIGH volume, high pressure (as much as 80-100 psi)
Ninety nine plus percent of the 10-20 million Gen I SBs produced were built with configuration #1
The less than one percent that were built with configuration #2 consisted of '63 to '65 mechanical lifter engines and (maybe, I'm not sure) the mechanical lifter LT-1s from the seventies.
Note that configurations #1 and #2 are STANDARD VOLUME. The only difference is the relief spring value.
Configuration 3 was NEVER, EVER used in any production Gen I small block. It is strickly AFTERMARKET.
So the real question is what is the justification for installing a HIGH VOLUME, HIGH PRESSURE pump. The answer is that it was developed for loose clearanced RACING ENGINES in the sixties to maintain 80-100 psi oil pressure at very high revs - 8000 RPM or more.
Does this apply to your vintage Corvette?
Does bubba the engine builder know more than the two generations of Chevrolet engineers who oversaw the design and production of 10-20 million small blocks, some of which carried 5-year, 50K mile warranties?
Has bubba ever heard the old adage: "If it works don't fix it!"?
If you have an engine that was originally equipped with the standard volume, standard pressure pump and a 60 psi gage, use the same setup, which is most cases can be the original pump if it passes inspection and most will.
If you have a late mechanical lifter engine with an 80 psi pressue gage, use the original 55-60 psi relief spring in a STANDARD VOLUME pump, preferably the original as discussed above. The reason why Chevrolet increased the pressure on late mechanical lifter small blocks is probably lost, but my '63 L-76 survived several hundred miles of race track hot lapping shifting at 6500 with the 40-45 psi spring.
Off course, when I hot lapped Kent I ran the oil level a quart over - a trick I learned from SCCA racers to prevent oil starvation due to uncovering the pickup and sucking air.
A road engine doesn't need more volume or pressure than it was originally equpped with and installing a high volume, high pressure pump will just increase parasitic power and heat up the oil since most of it will go through the gears and be shorted back to the inlet.
These oil pump discussions are as mindless as the engine oil discussions... so-and-so said... I heard... It's 99 percent myth and misinformation!
The facts on both subjects have been laid out here and in The Corvette Restorer many times.
be sure to check wear and all clearances at that time. That is just my opinion. Steve
). I replaced that very tired 350 with a built 383 and stuck that pump right back in the 383. All I did to the pump was run clean solvent from my parts washer through it, blow it out and oiled it before installing it in the 383. I also replaced the cracked plastic connector on the shaft. Now, after the 383 is heated up, oil pressure is about 55psi. That 383 is soooooooooooo much nicer than the tired 350!
