Hi all.....first post here, so to start it off, I was searching for a set of 1956 Corvette/Chevy Passenger car heads #3731762 and ended up with a complete long block assembly that was pulled out of a '56 Corvette that had been sitting unmolested for 20 or 30 years in Hawaii. The new owner brought the car to CA and turned it into a resto mod complete with C4 suspension, LS1 engine and six speed transmission.....oh well!
Somewhere in it's past history, the original owner replaced the stock powerglide with a manual transmission, so I ended up with a flywheel and clutch assembly......it would have been nice to have had the original PG, 2 x 4 manifold kickdown plate/bellcrank and linkage assembly, plus the PG block adaptor, but I guess we can't have it all!
The motor is in relatively good shape complete with a stock bore, stock sized bearings, stock #3711354 mech cam and it turns over quite nicely.....I have decided to retore it except for a modern piston/ring package and better rods.
I get conflicting information on how to decode the first seven digits of the engine block stamping.....I was told that the first five digits are gang stamped and the last two are individually stamped but unlike the later model block stampings that reveal the month and day, I get contrary explanations on the interpretation of the first seven digit sequence.
I get the F=Flint, 56=year and FG=225HP/Powerglide
0507153F56FG
John
0507153F56FG
John
