vacuum advance hold down screw - NCRS Discussion Boards
  • Ron H.
    • July 31, 1993
    • 96
    I am replacing the vac adv on my 327/365 . I can't get to the bolts down screw on the distributor plate that holds the vac advance in place. Does the distributor base plate rotate to expose the screw ?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: vacuum advance hold down screw
    yes it does. if the old vac advance is still good just apply some vacuum and if not just push it with a screwdriver
    • Michael F.
      • June 4, 2009
      • 291
      I work on mine out of the car. Holding the distributor you can rotate advance plate enough to loosen the screws.
