60 Tranny Problems All Gone! YIPPEE!!! - NCRS Discussion Boards
  • James S.
    • June 22, 2008
    • 226
    I want to thank all of you for assisting me in this dilemna.
    The flywheel bolts as mentioned were rubbbing on the upper inspection cover, so I remedied that problem. I also had the clutch adjusted improperly; not enough pedal play. All gears shift fine now and no noises.
    It was a combination of a poor rebuild from the first rebuilder and Chinese tranny bearings failed. They were loose after about 100 miles of driving.
    Thanks again to all of you.
    Jim
