Trim Tag rivet hole on 66 VETTE - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    Looking for the hole size thru the metal, that is used by the rivet to hold the trim tag secure ? DUTCH
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Trim Tag rivet hole on 66 VETTE
    This might help (if you're talking about the original hole size on the trim tag; not the mounting bar). This eBay example looks to have an unmolested holes. You'd have to scale from the pic to get an approximate size.
    • Harry L.
      • December 22, 2008
      • 370
      thanks Wayne, but I should have been more specific. I do mean the diameter of the hole in the mounting bar. DUTCH
      • William L.
        • December 1, 1988
        • 944
        Harry
        I think that it uses a 3/16 rivet.
        Bill
        Bill Lacy
        1998 Indy Pacecar
        • Russ S.
          • April 30, 1982
          • 2161
          Agree with bill. By measuring the back side of the rivet(which would be oversize after being crimped), viewing the front size, and being very familiar with these rivets I concur with him. Back side after being expanded on my trim tag measures.225. 3/16 is .187
          • Harry L.
            • December 22, 2008
            • 370
            thanks, what I want to do is drill the old rivet out,and put in a new rivet. So you would say that I would use a 3/16 inch bit. Then what would be the lenght of that rivet that I use? Is there a certain size cup used that holds the trim tag? DUTCH
            • Russ S.
              • April 30, 1982
              • 2161
              A drill bit could possibly drill off center because of the draw pin that is still inside the rivet. What I would do is carefully so you don't gouge the back side, is use a sharp chisel and shear off the back side of the rivet, then drill it from the front with one size smaller drill bit then a 3/16
              • Donald O.
                • May 31, 1990
                • 1580
                I'm just wondering why you'd have to replace the Trim Tag rivets........
