Re: Vavletrain instability small Block
Jerry said that he removed the stem seal from 5E to ensure a greater supply of oil down that stem. He also increased guide clearance on 5E to allow for more expansion. It's possible that 5E valve seat is too narrow...............maybe .030 - .040 rather than an acceptable .060 - .080, and not allowing enough heat to be transferred to the seat from the valve. Possible, yes. Probable?????
Sounds more like an oiling problem to me. He sees oil coming out the 5E pushrod at low speed, but maybe not enough at high speed. Excessive bearing clearances stealing too much oil from the top end to the bottom end? If so, then will need a high capacity (volume) oil pump. Open up the drainback holes in the lifter valley for faster drainback to the sump. Try using edge orifice lifters in the other 15 and a piddle valve type in 5E. Oil supply to the top end might be right at the "ragged edge" and it just so happens to show up on 5E first.
