66 Hood Emblem - location help - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    Can someone with a 66 please let me know the dimensions of where the emblem is located in relation to the side and front of the hood. Locations A and B in the attached photo? Also, if you think yours is the original location please
    So far I have checked two hoods and got 2 5/8" for measurement B, from the side edge of the hood to the emblem base on both of those hoods. However, one of the hoods measured 1 5/8" from the front edge of the hood to the emblem base (measurement A) and the other measured 2 1/4". I'm not sure if either was original, but a difference of 5/8" seems a lot.
    I also found a reference in a thread that said measure A, from the front edge, was 2" and measurement B, from the side edge, was 2 1/6". I can't find and dimensions in the AIM
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Terry L.
    • March 14, 2010
    • 53
    Re: 66 Hood Emblem - location help
    HI, MINE IS 2 5/8 AND 1 5/8, HOPE THIS HELPS, Terry
    • Donald H.
      • November 2, 2009
      • 2580
      Yes, that help. Do you know if yours is and original location?
      Don Harris
      • William K.
        • 37
        Check archives, I posted this same question before and received a nice diagram. Check under 66 template hood and side emblems.
        • W K.
          • December 16, 2009
          • 61
          Mine is 1 11/16" by 2 9/16"? The 1966 NCRS Technical Information Manual and Judging Guide does noy describe the exact location, other than "front left-corner of hood".
          • Donald H.
            • November 2, 2009
            • 2580
            Thanks for the replies
            Don Harris
            • Joe R.
              • May 31, 2006
              • 1822
              Don,
              Here's another thread that might help you.
              https://www.forums.ncrs.org/showthre...79123&uid=6140
              Joe
