64 Wheels - Early December car - NCRS Discussion Boards
  • Frank B.
    Infrequent User
    • January 1, 2000
    • 9
    My recently acquired 64 has reproduction knock-offs and I would like to replace them with wheels and hubcaps. I have purchased a set of early 64 hubcaps based on my Vin #...06680 with the correct frosting pattern. With respect to the wheels, should they or should they not have a 1/8" hole on the spider? And how would the car be judged given that the judging manual says "1964 model wheels are usually drilled with a single hole in the spider area that is absent in 1963 model wheels'? The spare has the double ridges of the 1963 wheel.
  • David L.
    • July 31, 1980
    • 3310
    Re: 64 Wheels - Early December car
    Frank,
    You may want to read thru the two threads shown below. There are probably still even more threads about 63-64 wheels.
    Dave
    https://www.forums.ncrs.org/showthre...=6994#poststop
    https://www.forums.ncrs.org/showthre...=2021#poststop
    • Tracy C.
      • July 31, 2003
      • 2739
      The only wheel you would be able to see the hole in the spyder is the spare and I would not expect to see one anyway on a VIN as early as yours. I thinks it was pretty late in the year before the hole showed up.
      tc
      • Frank B.
        Infrequent User
        • January 1, 2000
        • 9
        Thanks for the links. I had read those two particular threads and many others prior to my post. They provided a great of information and data. But I was hoping to understand the car would be judged and which wheels should I attempt to purchase.
        • Frank B.
          Infrequent User
          • January 1, 2000
          • 9
          Tracy, thanks for the reply and letting me know how judges would evaluate the car. Appreciate both you and David taking time to help.
