License Lamp Socket Removal/Reuse - NCRS Discussion Boards
  • Jeff Z.
    • February 1, 1994
    • 94
    Jeff
    63 Convert 340 hp
    66 Coupe 300 hp
    67 Camaro 1500 hp
    00 SS Camaro 320 hp
  • Greg T.
    • January 1, 2004
    • 136
    Re: License Lamp Socket Removal/Reuse
    Yep, Slit the outside lip with a Dremel cutter wheel 4 places. Clamp the housing and and tap under the lip with a sharp chisel to raise the lip. You can then release it. Clean it up and install it in the new housing. Support it from the inside. I used a socket that fit the ID with an extension clamped in a vise. Roll the lip back over with smaller sockets and you should be good to go. You just saved yourself one point!
