Here is the situation - 52 year old brakes on my 1959 - felt it was time to rebuild. Replaced all brake lines and hoses with new, had master & wheel cylinders board and sleeved, turned and resurfaced drums, pressure filled with silicone brake fluid and adjusted shoes. Result - no leaks, good firm peddle and stopping action is good EXCEPT they pull hard to the left. After 130 miles of soft gentle driving to seat new shoes to drums, I pulled the drums and inspected, found no leaks, primary (smaller) shoes in front position, and drum and shoe surfaces look OK to me. I then re-adjusted all four brakes and re-bled right front wheel position to no improvement. I am out of ideas and any suggestions would be appreciated.
Need Brake Help
Re: Need Brake Help
Paul, if everything's adjusted, there's only four things that can be wrong, all on the RF. First, the wheel cylinder seals (also called cups or caps) could be allowing fluid past them and the pistons are not working properly. I know that you had them sleeved (not my favorite thing to do). There also could be some trash in the line, probably at the wheel cylinder, providing enough blockage to allow only a small amount of fluid past. You could have a leak at at the fitting, although this is not very likely. But one of the most likely causes of your symptom is the collapsing of the flexible line when you hit the pedal. Did you replace these lines?
Paul- Top
Re: Need Brake Help
Thanks for the input guys - tried each suggestion to no avail. In frustration I put the car thru several hard brake stops, and low and behold, car no longer pulls to the left. Now working great. Beats me. Something must have shifted or seated. Guess a little anger every now and then is a good thing. Thanks again for the input.- Top
Re: Need Brake Help
You posted the same time I did. My guess is the wheel cylinder piston cups had not sealed. You'll need to watch this after your car sits, to make sure that that there is not a deformity in them and that they will continue to seal.Thanks for the input guys - tried each suggestion to no avail. In frustration I put the car thru several hard brake stops, and low and behold, car no longer pulls to the left. Now working great. Beats me. Something must have shifted or seated. Guess a little anger every now and then is a good thing. Thanks again for the input.- Top
Re: Need Brake Help
Paul,
I think I have an explanation.
I knew a car salesman that said if you open the hood and cuss the situation out and then just stare at it, it can fix things.
DOM- Top
