Front grill painting technique - NCRS Discussion Boards
  • Scott M.
    • April 30, 2002
    • 128
    I just got my front grills for my 72 back from the chrome shop. Now I need to paint the areas between the grill. Has anyone figured out the best way to paint the grill while leaveing the front edges of the grill chrome?
  • Pat M.
    • April 1, 2006
    • 1575
    Re: Front grill painting technique
    Scott I've heard some people mask off the front edges and paint, but they usually add that it's very tedious. I painted my 70's grill and then used a razor blade to cut the paint away from the front edges before the paint had really hardened, and it was pretty easy.
      • 6940
      Scott, I took some old pinstripping tape that I had and used that, It does take a little time, bring them inside and sit at the kitchen table with a towel down, or if you have a work bench with a stool, easier on the back that way, it can take about 35-40 minutes .
      Scott be sure to use some self ecthing primer on the chrome areas that are to be painted, Or the paint will flake off.
      • Sal C.
        • December 1, 1984
        • 430
        Spray them from the rear, as originally done and minimal taping will be required for accurate look.
        • Bill L.
          • February 1, 2004
          • 1403
          I did mine using a foam. I sprayed them from the back while lightly pressing them in to the foam. This method worked very very well. I had a little touch up to remove some over spray with thinner.
          Remember that an area around the parking lamp is black. I did use tape here and did the black first. There is a thread on the board somewhere with good pictures.
          You may want to use a scotchbrite pad and etching primer on some areas. Just make sure to tape off areas that you do not want to scratch with the pad.
          Bill
