My 66 has a rod that is too short and barely catches a thread in the carb fitting end, so I bought the correct one and low and behold because of the way the PO adjusted the accelerator pedal, the correct rod is too long.
I know from the drawings that the arm can be adjusted but I can't see how to get to it on the car. Any advice is appreciated.
My other choice is to cut the new rod, leaving it a bit longer than the old one, but that requires extending the threaded part which is a quarter-36 thread as far as I can tell and a die for that appears to be made from unobtanium.
Rich
Rich
