6 banger carburator adjustment - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12695
    A Belgium friend of mine has problems adjusting the three carburators on his '54 Vette. Is there an adjustment procedure somewhere documented he can use (manual, online, elsewhere???).
    He gets the first two adjusted but when the third one is done it spills over. The engine also sweats a lot...
    Help would be appreciated!
    regards,
    Rob.
    Rob.
    NCRS Software Developer
  • Joe R.
    • July 31, 1994
    • 287
    Re: 6 banger carburator adjustment
    Rob, I have documentation both from Chevrolet and from this forum, but I have to go home tonight and dig it up. It's very useful and accurate. Should I email to you? Hints: The throttle plates must first be set to fully closed by adjusting the linkage set. To do this means also to turn all idle adjustments fully UP. Then, the idle speed must be constantly adjusted to stay the same during adjustments! I think it's 475 RPM in drive. Then, the adjustments must happen in a set sequence.
    Joe Ryan
    • Joe R.
      • July 31, 1994
      • 287
      The "spilling over" problem is common with these side draft Carters. The factory spec for the float height is inaccurate. They must be set lower than factory spec by about 1/8" (3mm). The docs that I have at home explains all of that as well.
      Joe
      • Rob M.
        NCRS IT Developer
        • January 1, 2004
        • 12695
        Joe, I'm looking forward to the information you have got on this procedure!
        thanks for your help,
        rob.
        Rob.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12695
          This is the first part of the information I received from Joe (for other to use as well)
          http://www.musquetier.nl/images/Vette carb service book.pdf
          and
          http://www.musquetier.nl/images/Vette Carb Parts Diagram.pdf
          Furthermore I was pointed to some previously published Restorers articles on the subject...
          Rob.
