Re: Possible insight into the TDB "cam wars"
Hi Duke:
Yes, I thought valve size would be a factor in the calculation, with larger valves contributing to larger overlap area.
The comparison I posted was done with the same set of OEM 462 heads with 1.94/1.5" valves (as modeled in the EA library), so the only variable was the cam timing as represented in the EA library models for those cams.
That's an interesting point that the original Duntov cam had less overlap area when used with the smaller valves of the era.
Hi Duke:
