Well, another historic GM engine has finally "bit-the-dust". The 60 degree, OHV V-6 which first appeared in the 1980 Chevrolet Citation will be gone for the 2012 model year. Once an engine used widely across all of the GM car lines, it's last bastion of use was for the Chevrolet Impala which it exclusively powered for the last several years in both 3.5L and 3.9L versions. The 3.9L version was also used as the base engine for the Buick Lucerne for the last few years. The 2012 Impala will be powered exclusively by the 60 degree, DOHC V-6 and the Lucerne is GONE for the 2012 model year.
The 60 degree, OHV V-6 was produced in a variety of displacements over the years including 2.8L, 3.1L, 3.4L, 3.5L and 3.9L. There was even a relatively short-lived, 3.4L DOHC version of it which GM called the "Twin Dual Cam". This was one of GM's few forays into converting an engine designed for in-block camshaft to overhead cam.
While most other GM engines changed at some point to aluminum block, the 60 degree OHV was always cast iron for PRODUCTION applications although a SERVICE-only aluminum block was/is available for racing use. Most versions did use aluminum heads, though, except early 2.8L engines and all those once used in Camaros.
So, does the demise of this engine family spell the end of cast iron engine construction for GM? Not really. It seems that cast iron blocks using advanced technology, lightweight castings are creeping back in. In fact, the 1.4L 4 cylinder engine used in the Chevrolet Volt has a cast iron block. Could this be the beginning of "back to the future"?
I expect that SERVICE 60 degree, OHV V-6 engines will continue to be produced, probably in Mexico but, otherwise, it's RIP for this engine family.
So, now, as far as cars are concerned, GM has only one family of V-8 (the Gen IV small block), one family of V-6 (the 60 degree DOHC V-6), and one family of I-4 (the Ecotec family).
For trucks it's almost the same except the V-6 is not used and a truck-only family of inline engines of 4 and 5 cylinders (the Atlas engines) is used. Of course, trucks also have available the V-8 Duramax diesels, too.
