Which came first? - NCRS Discussion Boards
Which came first?
  • Rob M.
    • April 30, 2003
    • 657
    Which came first?
    Putting my doors back together and would appreciate it if someone could let me know which came first in the process - foam seal behind the vent window crank and the foam seal behind the window crank and THEN the vapor barrier? Or, vapor barrier and THEN the foam seals?
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Which came first?
    Rob,
    Put the vapor barrier on first. I used 3M strip caulk to mimick the original adhesive....then the foam seals.
    RestoMike
