Putting my doors back together and would appreciate it if someone could let me know which came first in the process - foam seal behind the vent window crank and the foam seal behind the window crank and THEN the vapor barrier? Or, vapor barrier and THEN the foam seals?
Which came first?
Re: Which came first?
Rob,Putting my doors back together and would appreciate it if someone could let me know which came first in the process - foam seal behind the vent window crank and the foam seal behind the window crank and THEN the vapor barrier? Or, vapor barrier and THEN the foam seals?
Put the vapor barrier on first. I used 3M strip caulk to mimick the original adhesive....then the foam seals.
RestoMike- Top
