1954 emergency brake cable seals - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    How exactly are the seals to be installed? Are they against the backing plate? Do the prongs face the front or back? Also is there a left and right cable or are they the same? Thanks as always
  • Guy M.
    • November 1, 1993
    • 499
    Re: 1954 emergency brake cable seals
    ok, no seal input, how about the cabe mounting bracket. Cant find a good pic but it has a flat side and a raised side. Is it correct the flat side sits on top of the bottom rail and bolts head is on the raised side? That would dictate which is a right and a left, correct
