I'm preparing for the PV at the CA capitol regional in October and my 64 has some regulator (spring) noise when operating the side glass. When I restored the car I did not change the regulator coil springs, I just cleanded an lubed them - still there is a little noise as the spring coils and uncoils. The PV guide talks about smoothness of operation and freeplay but does not discuss noise during operation. Just wondering if I need to pull them back out and change the springs.
PV and Side Glass Regulator Noise
Re: PV and Side Glass Regulator Noise
Jeff,
I think I would just pull the door panel and take some axle grease to them before going to the trouble of pulling them out. As I recall, they were gobbed (good word) with grease or something thick along that line. Probably old grease that had hardened.
JR- Top
Totally agree! My 64 windows were binding etc. Removed door panel etc. and located the spring, then flooded it with a spray can of white lithium grease. Presto, silky smooth. Give it a try!
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
OK, I did the passenger door tonight and it took some effort to work the grease into the spring coil but the sound is gone! I thought had done that when I had the regulators out the first time but I guess I was to stingy with the lube. One more thing off of the old PV check list. Thanks for the responses.- Top
