Re: 427/435 Fuel Pressure
Update
Well I have taken each carb apart, cleaned/replaced all fuel filters, put a # 28 squirter in the centre carb (was #21), blown out the fuel blocks etc and re-assembled. Set mixture screws to 1-1/2 turns and replaced base gaskets on all three carbs. Car fired right up and once off choke held 900 RPM with 6 lbs of fuel pressure and temp gauge showing 200 degrees. Raytech indicated 191 at upper hose thermostat housing. Revs nice and crisp with excellent response.
After approx 10 minutes the car simply stumbles and dies. If I jockey the throttle it will stay running and and clears out for about 20 seconds then its starts all over again ??? I'm stumped, I have Pontiac Tri-Powers (Rochesters), and have no trouble setting them up at all but this is off the scale.
The car does seem to fire right back up and will idle properly for a minute or two before going through the same cycle again. I have loosened the fuel cap (which is vented), and it made no difference.
One thing to note ... the rear carb is pulling some air at idle, while the front is not. If I put my hand over the rear air horn the car stumbles badly. Disconnecting the linkage make no difference. I will next review the Vacuum canister on the rear carb and then explore the TI side of things.
If there are additional suggestions out there, please feel free to fire away.
Thanks !
Update
Thanks !
