Hi all,
I searched a previous post for removing the white fan from a 68 smog pump (Joe L gave some good info). There is an "inner" ring and outer fan. I understand that the inner ring should be removed first before removing the fan. How is that accomplished exactly?
The inner ring is nearly flush with the top of the fan, and the outer diameter of that ring is a very tight tolerance to the inner diameter of the fan- (no clearance to get a thin tool in between them to pry the inner ring free). I struggle to understand how to get the two apart without causing damage to the existing parts?
Any insight is greatly appreciated.
Pat
68 427 / 400
88
Pat
68 427 / 400
88
