1967 convertible window felt - NCRS Discussion Boards
  • George T.
    • August 31, 1997
    • 9
    I just got some window felt from a corvette suppy. Its two flat pieces. I thought it would be pre molded. Should i buy the rear run with the felt already installed? Its seems like the flat pieces would be hard to glue in. I have talked about this before and got some great help from you guys. What should i do? Thanks again George
  • Steven B.
    • June 30, 1982
    • 3976
    Re: 1967 convertible window felt
    George, years ago I lined a set for a fellow. At the time the felt was very stiff---hopefully more flexible now. I had to repeatedly pull the felt over a dowel to lessen the stiffness. I used 3M adhesive and inserted the felt with a putty knife beginning on one edge, moving to the bottom of the channel and then up to the other edge. I did it this way to keep the felt straight.
    Steve
