I have decided to replace the steering box lubricant with lithium grease. I know there are opinions on both sides as to whether this is wise or not.
I loosened the side cover bolts and expected the lubricant to flow out, wrong. A few drips and that was it. I used a discarded 1" diameter feeding tube syringe attached to 1/4" poly tubing to extract about 3 ounces of the heavy oil. I then flushed the steering box with a quart of paint thinner.The liquid was never clear, but I believe the majority of the oil was removed.
Approximately how many ounces of grease will it take to fill the box? Or do I fill until it is near the top?
I assume at that point I need to drive the car and let the engine heat up the grease to distribute it evenly and then check the level again.
