1958 250 HP PG FI kick down for auto trans - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    Does anyone have a good picture or some data on how this linkage should hook up? thanks for any help
    Ronnie
  • Ronald R.
    • May 31, 1989
    • 670
    Re: 1958 250 HP PG FI kick down for auto trans
    The FI auto used the 3752490 rod and bracket assy and the 3750537 upper rod I can't find the lower rod number. Am looking for a source for all the items any ideas?
    thanks RDR
      Ron -
      Doesn't it show somewhere in the RPO 313 section in the Assembly Manual?
      • John D.
        • December 1, 1979
        • 5507
        My 58 AIMS has a very poor copy of the info Ronnie. I don't think it will be a whole lot of help to you. but it's a start. Page 157 in the Millenum Industries copy.
        For a perfect pic of that bracket see page 266 in Vol 1 of Noland Adam's.
        Then turn to page 289 for a mint photo that Noland took out of the aims.
        By the way Ronnie and others. If you are missing the FI accelerator return spring extention there is a print of that part in Nolands as the repro is too long. You are better off with making one yourself and making it a tad shorter than longer. Go to Lowe's and buy some S shaped hooks in a baggie then bent up your own and blacken it.Piece of cake. No I don't sell them.
        See Page 290 in Nolands for the print on that spring extension.
        • Ronald R.
          • May 31, 1989
          • 670
          John/John
          I have the firs addition 4th printing. From what I can see here 'It appears that the page 266 brackett is 3751674, for a carb. car?? The cut away on page 289calls fot 3752490??? I can't find the picture except on page 288?? It is not very helpful. It appears to me that the carb bracket which I found is too long for the FI car?? Any comments thanks RDR
          • Ronald R.
            • May 31, 1989
            • 670
            Tim Mickey
            Tim Do you have one of these cars?
            thanks RDR
            • Ronald R.
              • May 31, 1989
              • 670
              I have a 59 2x4 PG car that is very correct. Is this the same part number? If anyone can cross reference it I would apprciate it
              thanks RDR
