67 427/400 w/AC Temp Sender Wire Routing - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 303
    Can anyone supply some pictures of the temp sender wire routing. I'm especially interested in its path from the firewall up to the rocker covers as it runs past the accelerator linkage.
    I seemed to have developed a problem where the accelerator action is catching the wire and unplugging the temp sender.
    I'm also not sure how the wire lays in the tabs on the rockers that are supposed to hold this wire.
    Steve Gansky
    Newtown, (Bucks County) PA
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 67 427/400 w/AC Temp Sender Wire Routing
    The temp sender wire is in a "woven" loom at the top of the photo. I've had no issues. It goes down and away from the block at the rear and loops toward the firewall.
