counting teeth on speedometer drive gears - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    How do you count the number of teeth on a speedometer drive gear? These pictures were in previous threads I re-read today. For the life of me I can't get to 8 teeth on any of them -- as I understand it, the gears in the first 2 photos should have 8 teeth.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: counting teeth on speedometer drive gears
    Mark,
    I hear you, I tried to do the same and found that measuring the width was the way to go.
    I think I have the wider one that is for 3:70 and lower and I will measure it against the narrow more comon gear when I get to the shop today.
    I will post it.
    DOM
    • Wayne M.
      • March 1, 1980
      • 6414
      I can't remember which drive gears I used for the first two pics, but the third is definitely a 4.56 driven steel gear and the 6-tooth drive. I've shown in the attached thumbnail how to determine the number of teeth (impossible to count directly across the face of the gear, as only about 3 or 4 are in play at a time).
      Count the number of times a tooth merges at the circumference for one complete turn of the gear. I've marked in black ink on this one.
      • Domenic T.
        • January 29, 2010
        • 2452
        Here you go,
        I took pictures of the big & small gear.
        The best way to tell is to measure them, as you can see the diameter is larger for the 3:70 to 4:56.
        The comon one for the 3:55 to 3:08 is smallest in width and diameter.
        The large measures ABOUT 1.883 outside diameter amd .609 width.
        The small is 1.755 & .525. That can be done with a measure.
        DOM
