Brake caliper not releasing - NCRS Discussion Boards
  • Clayton H.
    • September 30, 2010
    • 4
    I have a 69 427 that the right front brake caliper will not release pressure. I originally thought the caliper was rusty and sticking, so I replaced the caliper. Replacing the caliper did not fix the issue. The other three calipers seem to function properly. Anyone know what could cause this issue.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Brake caliper not releasing
    hose is coming apart inside and acting as a check valve
      • 15573
      The rubber hose to the caliper fails internally and acts as a check valve to hold pressure in the caliper. Replace both front brake hoses. The other one is likely to fail also. You might want to consider replacing the rears as well. Nothing lasts forever.
      • Mark D.
        • June 30, 1988
        • 2142
        You might want to think about threading a piece of copper tubing...ahh, forget it.
        Kramden
          • 15573
          Now, now ... watch that fly boy. We are talking safety systems here and Clayton might want to (perish the thought) drive his Corvette.
          • Dick W.
            • 10483
            Izzat what USA does to yer 737?
            Dick Whittington
            • Clayton H.
              • 4
              Thanks for your reply. I changed the hose and it worked perfect.
              • Clayton H.
                • 4
                Thanks for your reply. I changed the hoses and it solved the problem. Thanks again!
                  • 15573
                  Clayton,
                  Thank you for posting the results. It is gratifying to know that a suggestion we made here worked for you. Enjoy your Corvette.
