Searching prior posts didn't turn anything up on this, so time to ask.
My '70 is missing the spare, completely. I happened across an AZ rim with a date one day earlier than my other (original) Rally rims. On the "new" spare rim, I happened to notice the "small B-B on the wheel" (pp. 50 in the TIM).
So I re-examined the TIM, and I began to wonder what is mean by "the low point" on the tire, which is the part that would "align" with the rim's B-B weld spot.
It sounds like they didn't want to spin-balance the tires/rims, so they somehow determined where the tire and rim were out of balance and put marks there. Then someone ran the machine to punch the tire onto the rim.
So my questions are:
1) Would I expect to find one of the "MICRO" balance weights at or near the same location as the weld? If they spin balance, the weight could be anywhere. If not, how would they know what weight to use?
2) What color orange is the dot? (There are millions of shades.) What kind of paint, keeping in mind it would have to adhere to rubber?
3) How far from the rim/tire juncture is the dot? Half inch? Inch? (It's a half inch in diameter according to the TIM.)
4) What do they mean by "low point" of the tire? If it's not perfectly round, you can't use it. So they can't mean the tire is out of round. Must be balance...
5) I read somewhere that it's OK if the spare's date code doesn't match the rest of the rims. In fact, in one place the TIM says only the spare is examined. But what about tire date codes? I think I found a good source of OEM tires, but tire date codes are (or will be) a question.
If anyone is interested, the tire source I found is:
Still workin' for a living, and apparently to support my car habit.
