1961 FI Gas Filter - NCRS Discussion Boards
1961 FI Gas Filter
  • Willie R.
    • June 30, 1982
    • 37
    1961 FI Gas Filter
    Iam sorry for asking this question, but my track record is overtighten & snap the plate on the gas pump side.
    What is the best way to install the cannester filter to eleminate leaking?
    Thank You,
    Willie Rotolone (5716)
  • Larry B.
    • October 21, 2010
    • 254
    Re: 1961 FI Gas Filter
    Hi Wille, Hopefully JD will chime in. He recommended Loctite 545 in one of my previous posts. It can be found on Ebay.
    • Don H.
      • December 1, 1981
      • 1482
      I use the two wrench method - one on the filter (5/8 I think) and one on the gas line fitting (9/16 flare nut wrench). Get them fairly close and sqeeze together. Good luck, Don H.
      • Willie R.
        • June 30, 1982
        • 37
        Thanks for the responses, will try .
        Again thanks
        Willie Rotolone(5716)
