1965 Emergency Brake Cable Removal - NCRS Discussion Boards
  • Jimmy B.
    • July 31, 1980
    • 584
    I have removed the e-brake cable from my 65 trailing arms but I am having trouble removing the cables from the ears on the crossmember (same one where the rear end snubber mounts). Is there a trick to this, I can find no clips to remove.
    Any help appreciated.
    Jim Blakely
    Re: 1965 Emergency Brake Cable Removal
    Jim Blakely
    Jim -
    Both sides should have the U-shaped stamped sheet metal retainer clips at those ears (similar to the clips used to secure the front brake hoses to the frame); see the Assembly Manual, UPC 5, sheet C2, View "C", item #34.
