1965 Rocker Panel Restoration - NCRS Discussion Boards
  • Dominic P.
    • February 1, 1997
    • 72
    FYI,
    I am need of original 1965 rocker panel restoration.
    Can someone please advise on who can re-anodize the aluminum rockers?
    appreciate the feedback on this topic.
    thanks!
  • Jim D.
    • 2882
    Re: 1965 Rocker Panel Restoration
    I've done a lot of research on this as I need my 65 rocker panels redone as well. I've looked at the repo.'s, they are absolute junk. I've looked at several NOS sets and have come to believe that NOS means Not Originally Satisfactory and they went to the reject pile to be sold as service replacements.
    Mr. Trim in Ca. has a terrible reputation so I would avoid them.
    I finally found someone who knows what they are doing. He strips, polishes, bright dip anodizes to the correct finish and then clear anodizes them. I'll be sending him mine this fall. http://www.trimrestoration.com/index.html
    • Dominic P.
      • February 1, 1997
      • 72
      Jim,
      Really appreciate your feedback....I will give them a try too!
      Thanks!
      • Alan D.
        • January 1, 2005
        • 2027
        The major problem with the restoration of original panels is finding a source to strip and finish base material before bright dip anodize.
        The general opinion was to do in two steps - 1 strip & polish base material and then
        2 send to get anodized. Make really sure it's a BRIGHT finish, most shops do not do the bright since its a different process.
        I have no knowledge of the firm listed above however I would want to SEE a finished panel before using them. (may want to do a search on 63 & 64 rockers)
        • Dominic P.
          • February 1, 1997
          • 72
          Alan,
          Appreciate your feedback!....will make sure the process you stated is followed!
          • Paul J.
            • September 9, 2008
            • 2091
            Jim, that's perfect.
            If you don't mind, would you post again after you get them back and let us know how they turned out.
            Paul
            • Blake W.
              • April 30, 2001
              • 164
              Jim, I also have a set of '65 rockers I would like to refinish. Took a look at the chevy restorer's web site; parts looked good. Is the black portion of the rocker applied over the finished anodized part or painted before the final clear anodize? Blake
              • Jim D.
                • 2882
                The black is painted after all the plating is done. I've seen Dave's work on a 62 Impala SS and the trim was FLAWLESS. He replates each step to exactly the same thickness as what the factory did.
                • Jerome P.
                  • October 22, 2006
                  • 607
                  I also am looking for someone to restore my '72's rocker moldings. They are, at best, in average condition. But in my opinion can be restored.
                  Have you sent yours to Trim Restoration yet and if so have you gotten them back? Are you satisfied?
                  Jerry
                  • Jim D.
                    • 2882
                    Jerry
                    I'm going to send them off this fall. I'll post my opinion and some pics. when they are done.
                    • Jerome P.
                      • October 22, 2006
                      • 607
                      Jim, I had Trim Restoration do my rocker moldings and they came back excellent.
                      Last judging meet, Tucson, AZ, the judges had no complaints. They all said they were great.
                      The moldings I sent needed some tender loving care, they came back prefect.
                      Dave Kosmann, the owner, is a real gentleman and will make every effort to meet your schedule. I paid $600. plus mailing costs.
