1954: replaced carpet, removed shift lever -- what next? - NCRS Discussion Boards
  • Rick G.
    • February 8, 2011
    • 41
    i replaced my interior carpet yesterday in my '54. in doing so, i removed the shift lever and the small ring with 4 screws which holds the shift lever to the transmission housing.
    the car appears to be in neutral now, and i wasn't sure if there is a special adjustment i need to perform to get the shift lever re-aligned with the transmission?
    i found this link for someone with a 1956:
    https://www.forums.ncrs.org/showthre...ssion&uid=3144
    and wasn't sure if a similar process was needed for a 1954. if so, i would appreciate if someone could shed some light on it.
    thanks.
  • Rick G.
    • February 8, 2011
    • 41
    Re: 1954: replaced carpet, removed shift lever -- what next?
    I figured it out.....I raised the car on jackstands, moved the linkage to park, then used a center punch to line up the bolt holes. I still need to make sure things are proper and it shifts correctly. But I think I am good to go.
