After installing the o rings on the lower outers the ring seems to not be thick enough. There is still a 16 inch gap between the shaft and ring. This happened on both sides on one side of the a-frame. The other sides seem to fit properly. I guess I will need a thicker o ring in two locations. I assume grease will spew out if this isnt a good seal. I bought these from CC and they said to install them in this location. Anyone run into this? Thanks as always!
