I did not see the front and rear baffle seal in the AIM I am replacing the support and shroud seals. I want to make sure I get them all.
70 350 A/C did it have front and rear baffle seals
Re: 70 350 A/C did it have front and rear baffle seals
Which ones are the "baffle seals?"
I don't recall any seals with that name.
PatrickVice-Chairman (West), Michigan Chapter NCRS
If you're referring to the lower metal baffle shield,(which has front and rear seals), your car shouldn't have one
- Top
I can`t figure out if this is just a seperate part of the radiator support or does it fit on the lip of the radiator.
me > Overstock Sale > 1968-1970 Corvette Radiator Upper Front Baffle Rubber Seal Replaces GM 3919753 USA Blueprint Accurate (See Item K)
Price: $5.00
Item Number: 1274401
Quantity:
* Whole number only
1968-1970 Corvette Radiator Upper Front Baffle Rubber Seal Replaces GM 3919753. Die cut sponge rubber with PSA (pressure sensitive adhesive) mounts on front upper surface of the lower baffle. Blueprint accurate. None better. Made in Bridgeport, CT USA- Top
Your pic is definitely a support. Just appears to be the 68 version, showing the K/L seals belonging to the lower metal baffle in my pic. I should also say the metal setup appears on the 70 SB but not the A/C variety.
Here's a pic from a vintage doc catalog,(vol.26 with the helicopter cover) showing the supports. Think you're referencing the wrong support
- Top
