Hood Latch Spring finish - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    Could someone better describe the finish on the cone shaped hood lock bolt spring. The Judging guide specifies "dark natural finish" . Also the return spring finish on the left side firewall mounted latch ? Thanks, AL
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
    Re: Hood Latch Spring finish
    Alger------
    I believe these release springs to be a gray phosphate finish and not a "dark natural" finish. In any event, whether or not they are actually gray phosphate, that is how they APPEAR.
    The pull-back spring on the upper hood latch plate is also a phosphate finish but much darker---more like what is described as a black phosphate finish. (note: no phosphate finish is actually black; they are all some degree of gray from a light gray to a VERY dark gray)
