'68 TI wiring harness routing - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 543
    I have several '68 radiator supports---small block, big block, with and without air conditioning, and with and without transistorized ignition.
    It is my belief that cars equipped with transistorized ignition had a "extra" hole drilled into the radiator support to accommodate the TI wiring harness.
    Please see photo below. The "extra" hole I'm referring to is the large (lower) hole that is missing the rubber grommet. Photo is of the left (driver's side) of the radiator support, looking from the front.
    I think this hole was added after the original stamping of the support because there is a "burr" on either side of this "extra" hole. None of the other holes in these supports have burrs.
    I'm thinking that this hole was "drilled" as needed, either at the manufacturer, or on the assembly line?
    Any input, thoughts, knowledge?
    On another note, I'm looking for a photograph of a block heater "plug" installed into a '68 radiator support.
    I have such a photo somewhere, but have not located (on a floppy--oh my).
    George
  • Henry J.
    • November 1, 1999
    • 457
    Re: '68 TI wiring harness routing
    George:
    My February-built 68 (originally L71) has the lower large diameter hole also. The hole is fitted with a grommet, so I can't feel easily for a burr.
    • Terry B.
      • August 31, 1999
      • 607
      George,
      My Dec '67 built '68 has just the large hole with the grommet. I think the hole was large enough to get everything through and no additional hole was necessary. Also, just found that the TJM states the TI wiring harness follows the same route as the vacuum hose and wiring harness through the radiator support.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • George W.
        • May 31, 2000
        • 543
        Interesting: we have these supports with and without the lower hole.
        Hey Grant, you following this?
        Joe, John, Clem?
        • Richard F.
          • May 31, 1986
          • 193
          Looks like the K66 page in the 68 assembly manual says to drill a hole at an existing dimple. Mine has the hole, so I can't comment on the existence of the dimple.
          • Robert M.
            • January 1, 1992
            • 78
            My 0ctober 67 build big block with TI has the 2 holes
            • George W.
              • May 31, 2000
              • 543
              Interesting.
              I have two '68 supports without the "extra" hole---one has a very small dimple, and the other does not. I have no idea what production number either of these supports were from.
              The dimple (as best I can measure) is in the "correct" position to be used as a guide for the "extra" hole.
              G.
              • Jack C.
                • September 30, 1992
                • 1090
                My Jan 22 built L68 has the two holes.
                Jack Corso
                1972 Elkhart Green LT-1 Coupe 43,200 miles
                Top Flight 1994, 2018 & 2021
                • George W.
                  • May 31, 2000
                  • 543
                  Do you have K66 Transistorized Ignition)?
                  • Jack C.
                    • 1090
                    Yes. Sorry, I should have noted that.
                    Jack Corso
                    • George W.
                      • May 31, 2000
                      • 543
                      And, is this lower hole where the TI harness passes through the support on the way to the amp?
                      G.
                      • Jack C.
                        • 1090
                        Yes. correct. All other vacuum and electrical pass through the top hole and both holes have plastic grommets.
                        Jack Corso
                        • Henry J.
                          • November 1, 1999
                          • 457
                          George:
                          It sounds like Jack's car is configured identically to mine.
                          On my car, the TI pulse amplifier was mounted immediately adjacent to the lower hole.
