Junction block wiring connections - NCRS Discussion Boards
  • Doug Y.
    • January 15, 2009
    • 62
    I am now ready to connect all the new wiring harnesses together and the engine compartment wiring to the fuse box in my '63 Coupe . Is it okay to spray the connections with white lithium grease to prevent any moisture problems or do I have to buy & use a "die electric grease"? Thanks for all replies.
    Re: Junction block wiring connections
    Doug -
    I'd use a dielectric grease - you don't want anything in there that's the least bit conductive. GM (Packard Electric) filled those connectors with dielectric grease, but that didn't start until 1969 or so.
    • Stephen L.
      • May 31, 1984
      • 3148
      Di-electric grease is designed for that purpose. White lithium is not. I'd use the di-electric grease on all the plug connections including the bulb sockets.
