C2 67 Back Up Light Switch Orientation - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2126
    I have an NOS GM service reverse light switch for my 67 4 speed Muncie Transmission. I also have a reproduction version. Both interfere with the (original) muncie when installed as shown in the AIM. In other words, the two wires and the molded grey covering hit the side of the trans, well before the two small attaching bolts are tight.
    I assume it should be installed the other way (wires out) and that I am reading the AIM wrong. Am I right?
    Also, does the lever with the hole for the "wire link" to the reverse shift arm point up or down? THANKS!
    P.S. Can't seem to find much about this in the archive. I can provide part numbers and a photo if needed.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • William C.
    • July 15, 2009
    • 239
    Re: C2 67 Back Up Light Switch Orientation
    Tom...Wires out and arm down..Bill
      Tom -
      Wires outboard, switch arm facing UP. See photo below and your Assembly Manual, section M20, sheet A2.5, item #4.
      • Tom D.
        • 2126
        Thanks again John!
        Michigan Chapter
        Tom Dingman
        • William C.
          • July 15, 2009
          • 239
          Tom..John is correct I meant up, Sorry..Bill
