Is there any documentation available that lists the serial number for the engine installed in my car. Car number 00454
1992 Zr1
Tags: None
- Top
Re: 1992 Zr1
I want to verify if it is a 375 or 405 hp because I heard that some late production engines were 405 in 92. I tried to see the serial number but it is hidden by the alternator and motor mount. If I had the build document I would think it would show the serial number- Top
Re: 1992 Zr1
The Corvette Black Book has the specific information you are looking for.
Attached Files- Top
Re: 1992 Zr1
You can order the original build sheet & window sticker for your Vette from the Corvette Museum. Check it out.I want to verify if it is a 375 or 405 hp because I heard that some late production engines were 405 in 92. I tried to see the serial number but it is hidden by the alternator and motor mount. If I had the build document I would think it would show the serial number
- Top
Re: 1992 Zr1
http://www.ecklerscorvette.com/corve...1953-2011.html
Peter, why pay Heckler's $19.99 when you can get it from the NCRS store for $16.00?Dick Whittington- Top
Re: 1992 Zr1
I have the original widow sticker but it doesn't list the HP of engine. Also I removed the tank sticker from the car gas tank and it doen't list the engine serial number or HP either.
Thanks- Top
Re: 1992 Zr1
I don't think the Black Book has the information needed in this case.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
- Top
Re: 1992 Zr1
Kenneth------
I have no information that any 1992 ZR1's were equipped with 405 HP engines. However, that doesn't mean it did not happen. Easy to check, though: look for the engine identification number which is found on the left (driver) side of the engine on the lower block rail, just above the oil pan.
If the suffix code "ZAA" is found, then you have a 375 HP version of the LT5 engine. If the suffix "ZVC" (or, some other non-ZAA suffix) is found, then you have the 405 HP version. I'm betting you'll find a "ZAA".In Appreciation of John Hinckley- Top
Re: 1992 Zr1
I agree. If a late 92 ever got a 405 I think it would have been later than VIN 454. Like Joe said, the numbers and suffix are easily read on the block rail by the pan.Kenneth------
If the suffix code "ZAA" is found, then you have a 375 HP version of the LT5 engine. If the suffix "ZVC" (or, some other non-ZAA suffix) is found, then you have the 405 HP version. I'm betting you'll find a "ZAA".Tom Hendricks
Re: 1992 Zr1
Here is the specific information from the Corvette Black Book:
1992 ZR1:
BHP = 375
Engine Suffix = ZZA
Block # = 10153558
Head Casting # = 10174389 (LH); 10174390 (RH)
1993 ZR1:
BHP = 405
Engine Suffix = ZVC
Block # = 10199001
Head Casting # = 10174389 (LH); 10174390 (RH)- Top
sorry.
