Need info on color red 1980 Corvette - NCRS Discussion Boards
  • Bill B.
    • December 1, 1993
    • 192
    Looking for id code for paint where to find it, or and location, name of color Red for 1980 and factory ordering information. Would this paint be a lacquer base? Was clear coat used?
    I appreciate it, Bill
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Need info on color red 1980 Corvette
    1980 Corvette red was called Red. Code 83.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Jim T.
      • March 1, 1993
      • 5351
      Bill all 1980 Corvettes were painted using lacquer at the St Louis factory. In 1981 Corvettes built at St Louis were painted with lacquer. 1981 Corvettes built in Bowling Green factory did not have lacquer paint and used enamel basements and clear top coats. 1980 Corvette red is Code 83.
      • Bill B.
        • December 1, 1993
        • 192
        Thanks, where can this code be found? Also can anyone provide the manufactures name and part or order number, I would even take an aftermarket number if it’s a close match to original color.
        Bill
        • Tom H.
          • December 1, 1993
          • 3440
          The color code can be found on the trim tag inside the driver's door jamb at the pillar by the hinges. A little plate about the size of a business card.
          If you just need paint, your local paint shop should be able to mix it up for you !
          Tom Hendricks
