Stamp pad thoughts/opinions??? - NCRS Discussion Boards
  • Matthew L.
    • August 29, 2010
    • 187
    Whats your guys thoughts on this stamp pad is it that bad of a restamp or could it be real????
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Stamp pad thoughts/opinions???
    Matt,
    Stamping doesn't show to have much age to it. Pad appears too slick w/o much grain. Fonts do not appear characteristic. Restamp?.....believe it might be.
    • Stephen R.
      • May 20, 2008
      • 302
      Looks like the assembly stamp is up under the head. I believe the heads were on when stamped. Thus no way could the stamp be that far up and be an original stamp. My 2 cents.
      • Dick W.
        • 10483
        Tonawanda stamped the machine code before the head was installed
        Dick Whittington
        • Stephen R.
          • May 20, 2008
          • 302
          Just to clarify, assembly dates for Flint engines were stamped after the heads were on and for Tonawanda before installation?
          • Larry M.
            • January 1, 1992
            • 2688
            Yes.
            Larry
            • Stephen R.
              • May 20, 2008
              • 302
              Originally posted by Larry Mulder (20401)
              Yes.
              Larry
              Steve
              • Matthew L.
                • August 29, 2010
                • 187
                So is everyone in agreement that it is a poor restamp? Does anyone think it could possibly be a factory production stamp. Is it me or does the I in the suffix code look like a number 1 turned upside down?? Also wouldnt the actual VIN# be gang stamped and thus be straight????
                • Robert G.
                  • May 31, 1990
                  • 429
                  I went through a few dozen photos I have of date stampings and none showed a 4 like that one. The pad surface is way too shiny compared to what I have seen before.
                  • Michael G.
                    • January 1, 1997
                    • 1251
                    This may be the case however broach, build date and VIN doesn't look to have all the characteristics of original machining and stamping.
                    Matt.....please keep in mind we're taking a "best guess" approach regarding the engines stamping.
                    • Dick W.
                      • 10483
                      First off it is a photo and they can be misleading. Secondly someone did the pad no favors when they cleaned? it so that it looks as it has been somewhat polished.
                      Dick Whittington
                      • Michael H.
                        • December 1, 1987
                        • 724
                        I agree, I have never seen a 4 like that either.
                        • Dick W.
                          • 10483
                          Just a few 4's No effort to verify authenticity.
                          Dick Whittington
                          • Frank C.
                            • August 31, 2003
                            • 170
                            Dick,
                            The small block pad is for my car. 66 327/350 A/C
                            Frank
                            Frank Clark
                            U.S. Army Retired, current serving DoD Civilian
                            C1 1962 300hp, 4spd. Black/Fawn
                            C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
                            C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
                            C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
                            • Peter R.
                              • June 19, 2011
                              • 233
                              What is the recommended way to clean the paint off a painted stamp pad safely? Mine is currently painted and I was planning to use paint remover and nothing that might risk scratching the iron surface. Would this be reasonable? Thanks.
                              Pete
                              1954 Corvette #814
                              1957 Corvette #646 -- FI, 3-speed
