C3 Heater Hose Bracket Removal - NCRS Discussion Boards
  • Chris G.
    • August 12, 2007
    • 44
    How do I remove the heater hose bracket mounted on the passenger side wheel well from the rivited bracket? I can see a gap underneath in the center of the mounting bracket.
    White 1970 LS5 390/454
    • 11608
    Re: C3 Heater Hose Bracket Removal
    Mine usually fall off...
    There are two tabs on the clip that hold it to the bracket. They often fatigue and can break, else you can bend them away and remove it.
    Patrick
