1965 Big Block Hood - NCRS Discussion Boards
1965 Big Block Hood
  • Brenton M.
    • May 31, 2006
    • 66
    1965 Big Block Hood
    I would appreciate your help on this issue, I've already had my hood painted upon installing my hood i noticed that there is two holes on the hood mounting pad that is bad, they both are missing the nuts. is there any way for me to repair this hood without damaging the paint. your help will greatly appreciated.
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1965 Big Block Hood
    Brenton,
    A pic of the area would aid us in making a recommendation.
    • Wayne W.
      • April 30, 1982
      • 3605
      The hood hinge mount is a flat plate, not individual nuts. You should look at it and make sure someone ( spelled bubba) hasnt made changes in that. If not the easiest thing would be something like a helicoil fix. If necessary the side can be slotted and a new plate installed. Shouldnt affect the paint other than black out.
        Brenton------
        I agree with Wayne. This problem can be repaired relatively easily using a thread repair like a Heli-Coil. However, for this particular repair I like the Thread-Sert type of thread repair. These are a lot less common than Heli-Coils and usually can't be found in a hardware store, but they are available from sources Like McMaster-Carr.
        Here's a link to McMaster-Carr:
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        • Brenton M.
          • May 31, 2006
          • 66
          Thanks guys for the help, I Was able to get a thred-sert to repair both holes they worked great. Thanks again for the help.
          • Domenic T.
            • January 29, 2010
            • 2452
            Brenton,
            Joe has the right Idea.
            I use riv-nuts on stripped plates or frame applications.
            They are great as they grip both sides and get tighter when you tighten a bolt on them.
            They do take a special tool and I would be glad to send it to you, I think I also have the correct thickness riv nuts at the shop.
            The riv nuts are placed in the hole and the back side is pulled to the plate with the special tool.
            DOM
