Removing A/C frigidaire label intact? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    I'm trying to remove a dated 'frigidaire' label off my '73 V.I.R. valve. Want to remove without ruining it. The original is very thin and VERY well adhered. Any ideas?
    '73 LS-4 454
  • Peter M.
    • April 8, 2007
    • 570
    Re: Removing A/C frigidaire label intact?
    '73 LS-4 454
    Try this. Let it soak for about a minute & then use a single edge razor blade to carefully lift the label off.
    • Domenic T.
      • January 29, 2010
      • 2452
      Rich,
      I remove them with a heat gun and it works great.
      You can use the rasor blade to get it started after heating the edges then heat as you pull back. Watch your fingers as I usually get the heat to close when I do it.
      DOM
