rear main seal 1957 - NCRS Discussion Boards
rear main seal 1957
  • Bruce W.
    • June 30, 1997
    • 358
    rear main seal 1957
    Had a rope seal which leaked replaced with a replcement seal from corvette central (not rope). after 50 miles it leaks worse. are these replacement seals any good. Should I go back to a rope seal? Any suggestions would be appreciated.
    Bruce
  • Greg P.
    1961-62 Team Leader
    • March 1, 1985
    • 55
    Re: rear main seal 1957
    Bruce you can use the rubber seal from Danchuks, they sell parts for 55-57 chevys
    • Joe R.
      • July 31, 1976
      • 4547
      Bruce,
      There is nothing wrong with using the rope rear main seal. You just need to find an old mechanic that's done them before. They are easy to install but the secret is not in the installation. It's in the procedure to warm up the engine, cool it down and wait 24 hours.
      Find you an old engine builder in your area. The old guys are eager to teach the secrets (methods) used for years.
      JR
      • Pierre J.
        • July 31, 2000
        • 193
        I've used the two pieces neoprene seals kit w/wire from Paragon on my '56 265 and my '57 283 and never had a problem. Had them now for over 6 years.
        Pierre
          Bruce
          Bruce-----
          The neoprene seals should work fine. TWO IMPORTANT THINGS:
          1) The parting line of the rear main cap and block needs to be sealed with a good sealer. Ultra Black RTV will work but I've used Permatex Indian Head sealer for years with no problems.
          2) If there is any damage to the crank seal surface, then NO type of seal is going to result in a leak-free condition. Damage includes general wear-down, grooving, nicking, etc. The seal surface has to be near-perfect for the seal to work. If the seal surface is not perfect, you might be better off with a PROPERLY INSTALLED rope seal, but you'll still end up with a leak.
