AC Fuel Pumps - NCRS Discussion Boards
AC Fuel Pumps
  • Mark D.
    • June 30, 1988
    • 2142
    AC Fuel Pumps
    Ralph Spears asked me to post these PICs. He stated the one with the circle around the AC came in the smaller box (on the left.) I'm sure he'll chime in to further describe them.
    Kramden
  • William C.
    • May 31, 1975
    • 6037
    Re: AC Fuel Pumps
    The circle is likely due to an insert being built into the mold to allow the part to be produced with or without the "AC" logo. Remember these days AC is just a marketing organization, so all "AC" logo parts are produced by outside vendors. It would be interesting to know what the manufacturing dates are on the Boxes, generally small print on the bottom of the box or one of the flaps.
    Bill Clupper #618
    • Dick W.
      • 10483
      Re: AC Fuel Pumps
      I think that Airtex is making all the AC pumps now. I have seen blank circles, in the area you are talking about, on their generic pumps
      Dick Whittington
        Re: AC Fuel Pumps
        Bill------
        Yes, AC ceased the manufacture of mechanical fuel pumps ABOUT 1985. After that time, these pumps were outsourced to other manufacturers. However, for awhile the outsourced pumps continued to have the AC logo cast on them. I suppose that GM had some sort of requirement that the contract manufacturers continue to brand the pumps AC. Or, it may be that GM transferred its tooling to the contract manufacturers who used it to produce some of their own-branded pumps as well as AC pumps.
        In any event, at some later time the "AC" logo was dropped altogether. I suppose that at some point AC-Delco decided that the branding was no longer important (or, important enough to incur an increased piece cost to sustain the practice). Someone may have figured that all that was important for branding purposes was the box. After all, virtually no parts supplied in AC Delco boxes were manufactured by GM anymore.
        • Ralph S.
          • February 1, 1985
          • 935
          Re: AC Fuel Pumps
          The boxes are dated 86 I still have the receipt in the box when i bought them in Oct.1986
          • Rich C.
            • January 1, 1994
            • 383
            Re: AC Fuel Pumps
            The difference in the 'yellow-gold' plating is interesting! Not a plating expert, but the one on the left looks like 'yellow di-chromate' over zinc as opposed to 'yellow cad' . Any plating scientists out there?
            '73 LS-4 454
            • David L.
              • July 31, 1980
              • 3310
              Re: AC Fuel Pumps
              Pictured below in my NOS AC 40777 fuel pump for my 1970 Camaro SS350. Unfortunately the pump is stamped "263K40777" on the flange (263rd day of 1971). There is no date code on the box. There is just the plain "AC" casting without any circle.
              Dave
              • Warren F.
                • December 1, 1987
                • 1516
                Re: AC Fuel Pumps
                My original fuel pump on my '71 LS6 is similar in appearance with the only difference being the position of the 3 inlet/outlet location on the bottom. Mine is dated 19K40770. Car has engine assembly of T0227 and trim tag date of H18.
                • John D.
                  • June 30, 1991
                  • 874
                  Re: AC Fuel Pumps
                  Any issues with running today's gas in a pump that's been sitting in a box for 25 years ?
                    Re: AC Fuel Pumps
                    John------
                    In my opinion, yes. I believe that the elastomeric components of the pumps have changed formulation over the years to be compatible with modern fuel formulations, especially ethanol blended fuels.
                    However, do I think that immediate, catastrophic failure will occur if one uses an old pump with modern fuel? No, I do not. I just think the life of the pump will be shorter than one might otherwise expect. I don't mean in terms of miles, either. I mean in terms of time, regardless of miles driven.
                    I think that as a safety precaution and to avoid being stranded somewhere one should keep a close eye on the fuel pump for any sort of leaks.
                    • David L.
                      • July 31, 1980
                      • 3310
                      Re: AC Fuel Pumps
                      Warren,
                      I would say that your "19K40770" pump is dated the 19th day of 1971 or 01/19/1971 which checks out with your Feb. 27, 1971 engine stamping and March 18, 1971 trim tag. The fuel pump was installed in St. Louis, not Tonowanda.
                      Dave
                      • Warren F.
                        • December 1, 1987
                        • 1516
                        Re: AC Fuel Pumps
                        David,
                        I did not know that they weren't installed at the engine facility, interesting.
                          • 15573
                          Re: AC Fuel Pumps
                          David,
                          Warren, If the part number is in the AIM, and it is for the fuel pump, the part was installed at St Louis.
